  • Replies 162
West
If you are in CA its easy. The best induction system made for the GTR is the stock arrangement with a set of Password JDM snorkels (made in CA) for the airboxes. Forget about the pod filter intake kits, they are hot air generators and power reducers for the most. They also tend to cause laminar flow and tuning problems for the airflow meters. Folks will work this out soon enough.
The GTR exhaust is just a matter of taste. Obviously I would recommend a Willall midpipe - wouldnt I - but the reality is that from the cat back there is little to be had (nothing, no power) in a full system. Why? The stock R35 system is totally straight through, and most of the aftermarket systems are actually smaller in diameter around the mufflers. True. For aesthetic pleasure then by all means go ahead and get a big shiny, but it wont sound/go any different to a stock system + midpipe :)
Edited by Martin Donnon
Thats excellent advice Martin. It is impressive how many of the standard parts on the R35 GTR can not be improved on by much. I have always hated buying a new car & having to rip the whole exhaust system off & chuck it in the bin.
At least with your midpipe it is a quick & easy mod & you get a great power/sound improvement without having to change the rest at huge expense. That money saved can then be put towards upgraded turbos instead!
I will try and answer that rather condensed post in point form......
1) Thats typical of an internal wastegate boost curve
Would a stronger pair of wastegates' actuators redice this loss in high rev range Martin?
Edited by 9krpm
No I dont think so 9krpm, I would suggest thats what the turbos have to deliver and between being on the edge of compressor and turbine flow, the whole system is starting to become 'on the limit' in terms of its response :P
Having said that the actuators used in this instance are 0.8bar units which MAY not be quiet enough for 1.4 bar application. On the flipside this gives the end user the great ability of being able to 'flick' the switch to a nice low boost level for everday driving that 1.2 bar actuators simply wont deliver. We will be mapping the next such installation with stock 0.7 bar actuators and a new RPM derived Wastage duty cycle table to deliver a similar result to aftermarket actuators and boost controller without the complication and expense :D
The project is nearly completed, a few more items to go and it will be all done, a big thanks to Martin and all the guys at Willall Racing who invested their expertise and have worked tirelessly on this project. The guys at Willall are undoubtedly the #1 GTR specialists in Aus.
Some pics:
For those interested the current mod list on this R35 is:
Engine and transmission:
Willall:
Turbo upgrade (WR35TT )
Front Mount Transmission Oil Cooler (WR35TC)
Rear Diff Cooler (WR35DC)
Front Diff Cooler (WR35DC-F)
High Volume Oil pan (WR35OP)
Trans fluid (WR35TM)
Diff Fluid (WR35DF)
Motor Oil (WR35MO)
Gearbox seals (WR35GS)
Mid Pipe (WR35MP)
PPG 1st gear set
HKS Super Sequential BOV Kit
HKS EVC 6 Boost Controller
HKS A/F Knock AMP Sensor
HKS super fire spark plugs
Cobb AccessPORT with custom tune
5Zigen downpipes
5Zigen Spec tune exhaust
AAM engine oil cooler with custom fabricated lines
AAM wastgate actuators
SSP RS Clutch pack
Duetschworks 800cc Fuel injectors
MCR/ARC twin intercooler kit
K&N Filters
Nissan Spec V radiator coolant reservoir and fittings
Exterior:
Password JDM:
RAM air induction snorkels
NACA ducts
Radiator cooling panel
Intake Manifold
Bonnet
Boot lid
Rear diffuser blades
Rear speaker shelf
Elevated rear spoiler
Door sill covers
Engine compartment covers
Stillen:
Front lip
Side skirts
Wheels, suspension and brakes:
Volk TE37 G2 wheel
Eibach springs
Cobb Tuning Anti-Sway bar kit
AP Racing J Hook Rotors Front
AP Racing J Hook Rotors Rear
Stillen stainless steel brake lines
Endless Brake pads
Interior:
MCR paddle shifter
Sparco Steering wheel
Works Bell Rapfix II quick release steering hub and flipper
Items soon to be installed:
Password JDM rear seat delete kit
Tecnocraft T1 carbon race seats
Stillen AP Carbon Ceramic brakes
Edited by SlipR35
Is the car actually going to see some track time or be parked outside cafés all day? .
Simple answer....if you got one you can....if not, well you know what to do :D
After seeing the custom race trailer thats built for it though I would "suggest" it might be a half decent Time Attack kind of thing - just a hunch is all :)
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
