Ok I was just mucking around the front bar looking at the fan, hoses etc when I noticed i have TWO heater cores .. each is about 2cm thick and the one at the front was completely COLD (after a long drive) and the one behind it was HOT AS.
Is this the stock system set up?
The core at the front doesnt appear to be connected to the one behind it (the HOT one)..there's about 5cm of space between them so um WTF ? I'm pretty sure I read somewhere that stock radiator is only about a 2cm thick core so I think I have 2 cores on my front reo bar ..one of them apparently doing nothing and no its not a FMIC, I only have SMIC with the stock piping going to turbo..
https://www.sau.com.au/forums/topic/284365-wtf-do-i-have-2-radiators/
It can't be blocking the radiator, otherwise your engine would continually overheat. Pretty certain the car manufacturers would have thought about this.
Air goes through the A/C condensor and then through the radiator. And it also has that dirty big mo-fo fan on the engine to draw air through both units.
Only turns on when the car temp rises and it needs it. Otherwise all your fan air comes from the motor driven unit.
If your doing say 40km/h, there is enough airflow so that neither fan is on - no fan is working. Its only in traffic and stinking hot days that the fan needs to work.
oh I see ... in that case my fan clutch may be sticking or something because I had the consult plugged in as I was driving and noticed it coming on very rarely even when the temps rose to 96c in traffic
when is the fan on top of the air condenser supposed to kick in ..when you switch the aircon on or is it supposed to be running all the time? I don't think I've ever seen it on
In the seven years this forum has been alive, no-one has ever thought to ask that question :yes:
Yep, it's already been solved, I know, but that's your air con condensor. I had EXACTLY the same thought when I first saw it... plus my front mount in front it both of those... was rather confusing for someone who didn't know how turbo cars worked... lol
There are some posts on here about wiring the fan to come on all the time (or be wired to a switch so you can control it) I thought... in the tutorial section. I believe it's for an R32... could be wrong about all this info by the way haha. But there might be some answers for you in that tutorial.
you're not mechanically minded are you denis? totally understandable, but I gotta admit it was a hilarious question hahaha
thank you thank you I try my best to amuse everyone :D
I'm not ashamed to admit I know next to sweet f'all when it comes to cars and a month ago I didn't even what a thermostat did exactly, today I replaced mine :cool:
Speaking of which .. I flushed the cooling system with some Nulon product (had to leave the thermostat out for this to save myself time when rinsing the shit out..) and refiilled it with the green Nulon premix (33% coolant 66 distilled water) Anyway, question is, aren't 34's supposed to take in 9 litres of coolant ?
I could barely fit in 5.5 litres and that's with the overflow bottle included .. yes I've bled the cooling system via those 2 screws on each side of the plenum (yes 34s do have 2 of those..) and radiator cap.
I've also drained the radiator and block (from the thermo side). Is it possible there was still 3.5 - 4 litres of OLD COOLANT left in the block on the right hand side and in the heater pipes? Seems kinda ALOT to be sitting inside half the block and heater pipes.. Oh yeah I did have the heater on full when flushing/rinsing the cooling system..
How much coolant were you guys able to poor in there last time you flushed old coolant ??
There is a bolt on the block, turbo side that you can undo to drain the block completely.
So yes there would have been some coolant left in the system.
But if you had the thing flushing for long enough it was probly just water.
yeah I know about that bolt on the right hand side but from all my research most people were saying to leave it alone because 1) it's extremely hard to reach 2) a total PITA to remove as its probably become a part of the block so to speak..
So no I didn't drain from that one, just from radiator drain and from the thermostat side. So question is, could there have been 4 LITRES of old coolant/water still in the right hand side of the block and heater pipes??
it is common for the radiator to be slightly blocked (which flushing doesn't clean out) and that reduces the amount it takes. also it isn't just the heater hoses that hold some of the fluid but the heater core as well. and without knowing how exactly you drained the coolant it is hard to say how much coolant was left in there. i know that when i drained my 33 i put about 7.5L back in (says it is supposed to take 8.5L)
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
