  • Replies 69
I've been thinking about this all day, still not swayed either way. I can see myself (and the missus) appreciating having the air con when staging etc coming into the warmer weather but also see that it IS weight that can be lost and a tiny bit less for the engine to do, though not much as it's obviously only requiring work when it's engaged.
Hmm... lol
Hmm... lol
Harden the f**k up. :(
Most modern shit cuts the air compressor out on full throttle. I think R32's do this, do S13's?
You don't sound too serious about getting an extra tenth out of your times, and personally, in your situation (already thinking about selling time) I'd leave the aircon in it. Rip the passenger seat out when you get to the track to save 10kg or so......
If you remove the aircon, it'll never go back in mate.
Those complaining that its hot???? Come on guys. I havea std radiator so drive at the track with teh heater fan on high and full blast to try and take heat out of the coolant.
My AC never got regassed after the engine came out years ago, then a line melted with the high mount so out it came, 10kgs is 10kgs
lol
resale and s13 in the same sentance
you guys are f**ked!
But is only ever gets driven on weekends :yes:
If its a track car rip it out and ditch it, chances are who ever you sell it to will use it for the same purposes anyway.
I'll see your permanently on heater (not because the rad can't cool, but because the tap is permanently on) and raise you one glowing exhaust system next to my leg. The rotary exhaust runs so hot I can smell paint on the trans tunnel burning at the end of each stage. Even the handbrake handle gets too hot to touch.
Not such a bad thing in winter, but it gets awful hot in summer (Gallangowan 2008 was a shocker. Even the water out of my camel back drink bottle was coming out hot enough to make a cup of tea)
But yeah - hot and sweaty is so much fun. Lucky I'm such a hard bastard :yes:
Dedicated track car - yeh I'd probably strip the A/C out if it wasn't working well. Anything else and I'd happily leave it in there.
Pull it out and stop being pussy. Silvia's aren't worth shit so why worry about resale. Its only going to go to a skid kid anyway when you sell it so it makes it more drift spec. Win Win.
I just put my battery in the boot so thats 10kg off the front wheels as I had a large battery and moved it as far to the rear left as I could and when I remove the aircon inc under dash that should be another 15kg off the front of the car hopefully.
Weight is weight and I have never seen Ash ever do a trackday so his opinion doesn't count :( Sorry Ash :whistling:
I'm with Bris. Std radiator and heater on FTW!
I'm in a similar situation, thinking of whether to take the aircon out or not. My main reason is to try and get as much airflow to the radiator as possible because out on track the day heat up here is a killer.
Edited by PM-R33
Something interesting to add.
I was at a drive course yesterday and had Luke Youldon as my driver/trainer and he insisted on having the windows up and aircon on explaining that the added comfort would keep me fresh and would do far more for lap times than the small reduction in weight would do.
Having said that, once he got out of the car I turned it off and put the windows back down as I prefer to drive that way. It was only 22 yesterday so it was hardly hot weather.
At this stage, it's still in the car.
lol
That aside, just saying it's a valid point. It was interesting to see how some people handled fatigue later in the day, which is when more 'incidents' occured. That will also be car fatigue, tyres etc, also.
Me, i just keep the windows down and kept my sessions to 5-10laps depending on how the car was feeling.
Windows down is far too loud and too much wind to hear what the engine, tyres are doing. Without wanting to sound like a tool, i am basically shit scared most laps i am driving fast so kind of focussed and dotn really notice if i am hot, or the cabin is hot etc. I agree if you are doing races etc. Bt i cant remember the last time i did 10laps in one sitting. Doing 5 laps at a time is a breeze, irrespective of ho hot the cabin may or may not be
I'm a windows down man, but I don't notice the heat in the car unless it's a long straight or it's in the pits really. I really just like hearing my 'gate open up which is better with the windows down :)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
