Japan Drift Road Trip! 3 Video Clips
Hi,
I went to the autumn drift festival with a couple of friends in my nissan s14. Craziness resulted. Hope you enjoy.
You can't embed these videos on the SAU forum is that correct?
Trip Up
http://vimeo.com/5335217
The Drift
http://vimeo.com/5502660
Trip Home lost in the snow
http://vimeo.com/5196570
Edited by NORMAL
https://www.sau.com.au/forums/topic/287789-japan-drift-road-trip-3-video-clips/
  • 5 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
Nice vids mate.
What do you think of the drive to Ebisu circuit (and the drive through f*kushima prefecture)? Is it a nice place?
I am possibly moving up there to live later this year (f*kushima prefecture), but have never been there before.
I know there is lots of countryside and mountains out there, in the capital f*kushima it may be more interesting, but there is lots of small towns you would probably be one of only a few gaijin(foreigners) in the area. It might get boring in the small towns, but f*kushima might be big enough, but its no Osaka or Tokyo.
If you are going for drifting only, to be close to Ebisu etc, it may not be a ral bad thing, cos drifting will be your fun I guess. There is probably a few foriegners living in or near nihon matsu now because of drift.
  • 5 weeks later...
thauiuiyuiuyiuyiuyiuyi
Hi,
Trip Up
The Drift
thax bro great job
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
