Just to chime in that there is another factory super turbo.
Golf GT :Dhttp://www.webwombat.com.au/motoring/news_...f-gt-review.htm
Love these cars and enjoyed the episode from mighty mods :).
  • Replies 80
  • 6 months later...
an update.....
we (well maybe I) decided it could live with some more turbo lag with the SC to look after things down low.
So it is at Hills Motorsport getting a GTR T28 turbo and new manifold put on.
At the same time it became clear that it has a fair bit of blow by already, so we have order a set of forged bottom end bits from some wierd little japanese car guy in hokaido that used to race them. and a catch can to keep it sort of under control in the meantime.
yep it says "an intake restrictor". that got a bit tricky for GTR with 2 intakes but the mighty march only has 1 intake.
I figure the only chance for a turbo car in IPRA is either spend way more than 1 can afford, or something light and small enough that the restrictor won't limit power. No chance of 900cc making make 350hp so I am safe.
oh yeah, just reminded me, the GTRs or and other car with 2 intakes need to run 2 26mm restrictors.
lol 7 bar sounds nice. might have a bit of trouble holding the head on.
in unrelated news....I saw pics of the super turbo's older brother today....its a 1985 K10 March Turbo. Love the dash and steering wheel...
they dont have any trouble holding the heads down, the problem is stopping the block splitting in half and leaving the crank + pistons down the bottom and the head/cyls elsewhere. :/
Just reading the regs on all of this duncan, I think you'll be stuck with two restrictors...
For vehicles utilising a turbine type compressor, the restrictor must be fitted as per diagram 254.4 (see “Rally/Road” in the CAMS Manual of Motor Sport), save that the maximum internal diameter of the air intake into the compressor is 36.0mm where a single supercharging device is fitted, or 27.0mm where two devices are fitted.
PS: I haven't finished reading ths damn 3 million page long manual, so there may be something I've missed...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
