Just to chime in that there is another factory super turbo.
Golf GT :Dhttp://www.webwombat.com.au/motoring/news_...f-gt-review.htm
Love these cars and enjoyed the episode from mighty mods :).
  • Replies 80
  • 6 months later...
an update.....
we (well maybe I) decided it could live with some more turbo lag with the SC to look after things down low.
So it is at Hills Motorsport getting a GTR T28 turbo and new manifold put on.
At the same time it became clear that it has a fair bit of blow by already, so we have order a set of forged bottom end bits from some wierd little japanese car guy in hokaido that used to race them. and a catch can to keep it sort of under control in the meantime.
yep it says "an intake restrictor". that got a bit tricky for GTR with 2 intakes but the mighty march only has 1 intake.
I figure the only chance for a turbo car in IPRA is either spend way more than 1 can afford, or something light and small enough that the restrictor won't limit power. No chance of 900cc making make 350hp so I am safe.
oh yeah, just reminded me, the GTRs or and other car with 2 intakes need to run 2 26mm restrictors.
lol 7 bar sounds nice. might have a bit of trouble holding the head on.
in unrelated news....I saw pics of the super turbo's older brother today....its a 1985 K10 March Turbo. Love the dash and steering wheel...
they dont have any trouble holding the heads down, the problem is stopping the block splitting in half and leaving the crank + pistons down the bottom and the head/cyls elsewhere. :/
Just reading the regs on all of this duncan, I think you'll be stuck with two restrictors...
For vehicles utilising a turbine type compressor, the restrictor must be fitted as per diagram 254.4 (see “Rally/Road” in the CAMS Manual of Motor Sport), save that the maximum internal diameter of the air intake into the compressor is 36.0mm where a single supercharging device is fitted, or 27.0mm where two devices are fitted.
PS: I haven't finished reading ths damn 3 million page long manual, so there may be something I've missed...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
