Putting in splitfires soon and wanted to put NGK BCPR7ES-11's in (the ones that come in 1.1mm gap from factory) but apparently NGK dont make these ... they make BCPR6ES-11 and BKR7ES-11 but NO BCPR7ES-11 What gives?
The BKR type of plugs are 2.5mm shorter than the others so I'm not sure I want those in there .. any particular reason why NGK would have chosen not to make BCPR7ES-11 that anyone can think of ?
  • Replies 41
i remember these were the only ones available a few years back. it used to shit me because i allways had to gap them down. maybe they stopped making them because the .8's were selling more ?
why cant you gap them ?
I could but I'd prefer not to ..we're talking fractions of a milimeter and I'm not sure I trust any mechanic to gap all 6 of them accurately. I'd prefer them in that gap size from factory ...also less risk of the tip being damaged etc during regap.
Having said that ..even though NGK.com.au doesn't show BCPR7ES-11 in their parts list there appear to be plenty of shops that sell them (googled it) ..wtf?
how do you know if someone in the shop or the packagers who pack them at warehouse did not drop the plug or the box the plug is in before you buy it?
you should check the gaps on them anyway.
with the tool designed for it :D
QFT!
Pretty sure I have BCPR7ES-11 gapped down sitting in my RB20 right now :3some:
If you cant find them just use BCPR7ES if you were going to gap them down anyway whats the point in getting a 1.1mm gap unless you cant find the 0.8 which you can get your hands on from your post :D
If your mechanic can't gap a spark plug, find a new mechanic. It's not rocket science.
Even from NGK, you should still check the gaps as you install them.
Are you sure you need a 7 heat range?
I don't believe I'm reading this , if feeler gauges are good enough to set ancient contact points they're plenty good enough to gap a spark plug .
Feeler gauges are a glorified go/no go gauge and repeatable accuracy gapping spark plugs is childs play . We are talking to the thou or 0.0254 of a mm .
Simply open the gap up a tad with a small flat blade screwdriver , insert the appropriate feeler gauge finger and gently tap the outer electrode till it closes up on the feeler gauge leaving a neat fit - bingo 1.1mm or 0.0433" (tad over 43 thou) gap .
Plenty of people have opened up the gap on std plugs or closed up wide gap ones if they couldn't buy the manufacturers set gap .
A .
Howdy again mate, I changed my sparkies about 2 weeks ago. Used BKR6ES 11's I'm quite sure, gapped them down to 0.90mm using a proper spark plug feeler gauge - only like $9 from supercrap. Very easy, very accurate. Just do it :3some: Just put some paper towel or something on top of the hard surface you put the plug on to prevent scratching.
yeah i wondered that myself a while back until i actually looked up what the 2.5mm difference was. as tony has shown, it is only in the top section of the plug. the threaded section and electrode aren't affected. if the springs in your coilpacks were shot (or missing, LOL) then you may have the slightest issue with the lead section of the coilpack not contacting the spark plug properly, but as i said, i don't think it makes any difference in normal circumstances
hmmm, i just changed spark plugs on the 34 gtt
went from ngk PFR7G gapped at 0.7mm to BCPR6ES gapped at .8mm
after the swap i now have a missfire at idle.
i used to run the 6 heat range in my 33gtst with 190rwkw no problem (both cars running splitfires)
i assumed the 34 would be the same but apparently standard heat rang is 6 for them not 5 like the gtst.
So im guessing going back up to a 7 heat range would fix this?
What is the difference of the PFR7 plugs compared to the BKR7ES plugs?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
