  • Replies 306
Posted Images
Volunteer! Then stay Saturday night.
Seriously. Volunteering gets you the best seats to watch, plus you can get free spins in peoples cars after the battles are over (bring a helmet, or borrow on the day).
Just so we are clear its free spins as a passenger.
http://www.tracksidetyres.com.au/tyre_breakingIn.html
That's a good link mate! I've never been able to allow a proper cure time coz I don't have enough tyres to keep racing on the first day.
+1 for this, I managed this for my re55's and now they stick like s**t.
Use a practice day to get them up to temp, then "practice" the rest of the day on your roadies.
3. Vehicles
• Cars presented to the scrutineer not ready for competition will be denied entry to the event.
• Cars must be considered ‘roadworthy’ and will be subjected to an examination.(Scrutineering)
• Tyres must be roadworthy to enter the road events on the DECA highway circuit.
• Seatbelts must be fitted to the vehicle and must comply with the current Australian Standards.
• All loose objects must be removed from the vehicle
• Tyres other than designated road tyres (Slicks) may be used and times will be recorded but you will not be eligible
for any awards
• All vehicles must be equipped with a minimum 900gram fire extinguisher securely mounted inside the vehicle with a
metal bracket. Extinguishers must comply with the Australian Standard – AS 1841 and not be more than five years
old.
If it is screwed in or cable tied it will not pass. It must be bolted in.
If "loose" objects are defined as anything that is not bolted in, what about items that are in the boot such as a stereo? I have gear that is screwed in, so does that mean this must come out as well? Thanks.
If it's very well mounted it may be ok. I would take it out regardless.
If not done already can you please group us guys.... If it's not too late.
5 Russell Cunningham R32GTST RWD
29 Matchewdick Femino R32GTR AWD
45 Tim Bryan 180sx RWD
46 Cumballs Shobbrook R32GTST RWD
Thanks Russman,
I'll take it out just to be sure. My idea of well mounted may differ from the opinion of the scrutineer's :devil:. My intent was to run the car in full street trim where possible so that I get a realistic idea of how the car handles for once it's back on the road.
nice one russell!! :devil::P
Thanks Russman,
I'll take it out just to be sure. My idea of well mounted may differ from the opinion of the scrutineer's :P. My intent was to run the car in full street trim where possible so that I get a realistic idea of how the car handles for once it's back on the road.
Don't worry. A 10kg subwoofer won't drastically upset you're handling. :devil:
Hah, you should see Gary Swift's Soarer. Got enough subs, amps, party speakers and lights in the boot to out weigh the engine.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
