'sif not, Mars... C'mon, you know you want one! Just think of all the extra vinyl you can lug around - I've been there and can attest to its crate and equipment lugging capabilities...
sif Vinyl.. 2006 man! i carry a laptop.
do you use finalscratch by any chance?
spotted some poopra sprinkled between some skylines... and some nutter in a maxima.
1.21.2 is my best so far in race spec, first time out in the skyline...I think it has more in it once it has a tune
thats pretty good man, wat sort of mods tho? like tyres etc?
the car is pretty much stock....stock turbs, stock boost (0.8bar d'oh), stock brakes, stock injectors etc etc. Yoko A032R are the control tyre. Has some jap coilovers. Thats about all.
I'm doing OK but the BSM GTR was quicker in both races I did last year. Missed the whole season this year but am ready for a big year next year.....doing the 10 NSW rounds, and we've just put the entry in for Targa Tas too.
Who is your mate? there are a few commodores out there but in a different class.
also spotted marssssss in teh city...
2GU UP near my place on my home... loving that car anth :ermm:
and DUNCAN: my mates name is Mik, not sure on his surname, he drives a white commodore, usually up the front of the field....if u show me some pics i can point him out, coz iv seen ur car in some of the pics he has, in the forground and background.... he's usually up there with u and the other GTR... hahaha i saw one pic of a race start out at wakie, and all u cud see was the 2 GTR's about 60-100 m ahead of everyone off the start lol... go the 4wd :happy:
Spotted a 32 plates 'FLY-xxx' absolutely SMASHING the industrial area carpark out the back of my place. Sounded like a good solid 2 minute burnout. There was smoke over the joint for about 5 minutes afterwards. :happy:
Spotted a white R33 (series 2 i think) with Dark rims, looked a bit like R32 GTR rims, and an R33 GTR wing just then at Sylvania heading towards Tom Ugly's Bridge
Waved, but i dont think the driver saw me
spotted '32ZILLA' at livo kk carpark last night lol .parked right next to me, also a white 34 gtt, gunmetal 32 gtr and black 33 gtst says 'fussys' on his cooler.
oh and it looks like theyre opening a harrys hotdogs there too. :)
Note to all, if you were in the city last night and got told to do a burnout by a drunken moron, that was me, every skyline etc i ripped into and tried to get a show. Another Note to all, you are all weak sauces and no one bagged it up!
Spotted alot of 33s in city last night
smokey in coogee today struggling for traction you hoon!
ummmm thats all i can remember after last night
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
