Yeah, me :)
I was driving right beside you the other week at Artarmon!
oh, i'd probably rolled out of bed and into the car to get to work....i'll keep an eye out for you! I've only ever seen silver V35's, would be nice to see a different coloured one!
spotted and got a wave from RLX RE a black r32gtst with vented bonnet and massive rims especially on the rear(big camber)
on the way home from penrith on the great western highway,very nice ride dude.
you were blowin abit of black smoke though dude otherwise sounded sweet-az and looks to match.
spotted mass in kings cross tonight. i was shotgun in the black r34 going the other way.
haha i didnt see u did i???
or maybe i did... the only 34 i saw was along the main strip??
u shud have said something...
spotted a few lines out last night.... was bored so went for a drive with my little bro :P
yeah that was us. you didnt notice it was me though, i had turned around from looking at all of the decently dressed girls and i saw your head infront of me. it was too late by the time i noticed.
ill shout out next time.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
