Spotted a white R32 GTR plates "OSAKA" on Epping Road today.
I was next to you in a white n14 pulsar for a bit.
that's been on a heap of pizza cruises. can't remember the owners name
i do remember it's LOUD though
Randomly spotted d00dz and Miss Turbo in Hakuba, Japan today
reminds me of the olden days when I used to spot the whore cruises randomly...
lots of fkn snow here... it:s siiick!
spotted smasha again today!
oooooooooooo
Snow's fken awesome!! I love it!
Seen a nice black R34 coming the other way in central Wollongong - saw you wave, hope you saw me wave back (at the last moment when I spotted you :laugh:
Spotted a white(?) R33 near Wollongong... and another 33 heading towards Jamberoo...
Spotted a gunmetal grey R32 (I think it was a GT-R, I couldn't see it properly and was too tired to get up and check) on Ballandellla Road in Toongabbie this afternoon
Spotted at Thornleigh Maccas this evening about 11:15pm a nice Silver nissan 350Z and an awesome wide body RX8(F&F style) white with graphics and carbon fibre hood, looked great.
Also spotted a white R33 on pennant hills rd after this, hope you didn't go past the speed trap too fast!
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
