was drivin next to a black R32 Gts-t,plated SLO-32W at James Ruse Dr, Rose hill on thursday 11-03-10 around 4.30pm in my blue R34
spotted a white R32 GTR plated WPN-26T near UWS Parramatta today around 5pm-ish
this afternoon saw a silver 32 GTR on richmond rd i believe.
A White 33 GTR near m7 bridge intersection waiting upon the lights.
just 20 mins ago saw and cruised with another 32 GTR with those pearlescent coloured rims starting at the intersection near maccas on windsor rd following each other all the way untill merging onto macquarie rd :blush:
R34GTR is on bakes BLACK R34 and he lives in Newcastle....
Spotted KIW 18U on Old Windsor Rd on Friday and then I was going down Norwest Blvd and I heaqrd a car come past soooo fast and its IMED (not sure if the plate is correct) the White R35 GTR
Sounds tasty
Spotted a white s2 R33 GTSt with gold wheels (kinda like CR Kai's) in Seven Hills this afternoon turning onto Prospect Highway from Station Road, then just a moment later spotted KIW18U (Bayside blue 34 GTR) parked at Riley's Gym.
Sounds tasty
Plates are INMED. This dude that lives around the corner from my house owns it. He either works at resmed or the new bella vista hospital (obviously lol)
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
