spotted greyish, maybe gun metal gray r34 vspec 2 gtr, with the plates vspec2, on forest rd penshurst dominos, i was the half naked guy standing on side of the street with a dominos chick in a square suit made of pizza deals :D
oatley on friday saw a white r33 GTR parked outside coles then a black R32 gts
then saturday saw a white R33 gtst cruising next a white ferrarri which im pretty sure is owned by one of the queens st customs guys at their shop, the one down the road from bankstown airport (not sure of suburb)
Just spotted a white r33 gtr on Richmond rd/ Knox rd, looked nice except for those ugly bling bling tail lights..
U gassed it at the lights abit,, were u wanting a race? Abit silly since I had a 7yro in the car
Cruised with a black na R34 4door along Pennant Hills Rd and up the freeway all the way to the Gosford exit at about lunchtime today.
Edited by Jay.R34
Spotted Mr Doof in Chatswood area on Friday night on the way home from Twilight drift. Turning right onto pacfic highway. Was in my mates car so i just yelled at you haha.
Spotted a white V35 sedan parked on Hawksbury Road in Westmead today, behind Westmead Hospital.
Also, I've been spotting a non-turbo black R33 coupe parked in Girraween on Targo Road a few times lately.
That was MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE..............................
i spotted you on the M2 made my way up to you, was great i had Eye Candy pretty much all the way home, Just moved up there :D
spotted a KV2 silver R34 coupe turning off Prospect Hwy onto Station Rd in Seven Hills
Also spotted a wingless gunmetal grey R32 burble past me turning off Prospect Hwy onto Lucas Rd in Seven Hills
if any of you guys are on here, heya, i was in the black R34
saw this in chinatown other day, opposite the capitol theatre and harrys hot dog stand..beautiful in nismo blue.
spotted the white one on bathhurst st last week i think. sorry, slow at getting phone near the laptop :P
spotted silver series 2 on james ruse drive at around 2ish i think it was
spotted a white 33 on the freeway heading south bound
had GTR kit on it * could of been a GTR *
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
