With the increase in number of "I spotted so and so Skyline" this is the official one for NSW (well I hope so)...the other states have one...well Victoria has one...
so start off...
I spotted a Maroon R32 GT-R around the South Strathfield area. I need to ask dude - why did you change your light set up? Moving the indicators to the outside hotplates looks wrong. Especially when braking; I thought you had 3 busted taillights (the one on the right middle is out btw.)
https://www.sau.com.au/forums/topic/29195-official-nsw-skyline-spotted-thread/
I saw two R32's on the Central Coast on Tuesday night heading toward Mingara,
Both had AUTOSTYLE stickers on the sides, both had personalised plates, but I cant remember what they said.
Perhaps UR..... something...
I see MADGTS all the time on fullers rd. But no one waves to me when I am in teh exa.  :D
That's Zane. He's on the forums somewhere and comes to track days at EC.
I spotted fatz new toy. Beastly thing I must say!
CerealKiller - that tail light rewiring your talking about is standard on the aussie delivered GTRs the outer one is the indicator and the inner is the brake light with the lil square as the reverse light
IMO i think its oright i like it cause it gets rid of the reverse lights next to the number plate and there is a nice panel that finishes off the rear bar around the number plate mount instead of having big gaps up the top where the number plate lights are.
oh yea and i saw a nice sliver GTR in the back streets of gladesville yesterday i think its from BD4s
anyway its just my 2c
:D
I spotted a midnight purple GTR in Longueville... It was uncanny... Exactly like my one!!!!!
You'll never believe where I saw it though......... IN MY GARAGE!!!! How freaky is that???
2 GU UP , you're kinda hard to miss lol
I was in the saab...but we do have an SAU sticker so that's no excuse.
You have to wave, its one of the forum rules.
(except for fatz, if you see him on the road keep out of the way :( )
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
