spotted a certain red 180sx on the back of a trailer heading south along the M7 near the tolls just after 7 this morning.
Also spotted a pretty clean white 33 gtst on the m2, plates were pyro something etc
Silver R34 GT??? for sale at Albion Park.
Forest green R33 in Shellharbour.
Charcol R33 coming down Maquarie Pass, waved, didn't get a wave back.
Hey dude. Pretty sure I saw you heading out toward Robertson earlier at around about 12:15? Don't know if you saw me wave back. Haha.
Yeah mate saw you rolling. Spot the undercover in the 50 zone there?
Nah mate, wasn't paying attention. I was sitting on 50 anyway. Did see some poor twat pulled over near the BP by a marked Highway Patrol where they normally conduct those roadside RBTs though just outside the pools.
Nah must've happened after I rolled through. Theyre always there.
Yeah, they always pick the same spots to do their RBTs. Near the cemetery where I saw you, outside the pools and just before the freeway entrance near Bunnings. I hate the spot outside the pools, got waved in for an RBT there on one occasion and after they let me go, there was a massive ditch at the end and their squad cars blocked the all the space around it so you had to go over it. Spun my wheels on the gravel by accident cause I rolled back slightly as I went over the ditch and they all looked at me, I was shitting massive bricks. LOL.
Edited by JDM34
I keep driving to/from work with a white 34 GTT with black wheels and SAU & Envy stickers on rear qtr passenger window.
I'm in the Bora 4Motion. Or on my pushy. :D
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
