Got absolutely owned by a Charcol R32 GT-R (with bonnet scoop) today turning onto Old South Rd heading towards Mittagong.
Sounded like sex.
Edited by Tai1or Made
spotted a certain red 180sx on the back of a trailer heading south along the M7 near the tolls just after 7 this morning.
Also spotted a pretty clean white 33 gtst on the m2, plates were pyro something etc
Mine. Plates are PYR 0IB. It was filthy, car looks so much hotter after a 4 hour detail wash and polish
I take it you where the black 34 GTR heading into the epping tunnel
Edited by ianjb
Sounded like sex.
Saw that guy the other day, did it have a loud ass exhaust? I was walking along the walking track and I heard him from 1km away. Lol.
Just spotted 2 x liners on Help Street in Chatswood
Gun metal R32 GTR with a SAU sticker on the right rear-quarter
Yellow R33 with White LM's (?) and a SAU sticker on the top rear window
Kind looked like R32 was raging at the slow ass infront of him lol
You guys were about 2 minutes apart from each other at the intersection of Help and Princess Hwy. I was looking down at everyone getting smashed with rain in the brown building on the corner lol
Spotted this dude fly into the canal today on my way home from work, went down to see if everyone was OK and help if needed but they went ape shit and started yelling at everyone and throwing shit so I just went to my car and left, I know it's f**ked up but people were trying to help and be nice dude.
the space saver on the rear says it all
sounds like nobody was hurt too bad if they could carry on like morons & throw shit at people :blink:
looks like the canal between campsie and burwood
Yeah its off croydon road croydon park on your way to campsie, the freakiest thing is that i was driving right behind him, he was driving fine until we got to that bend and he went agro or tried to drift it around the bend and lost it.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
