Spotted a white 32gtr at space station (shell) on epping road at 4.20pm today. Car had a sau sticker on the qtr window :)
That was me DIF! Yew!!! No mention if the car looked any good dammit!
spotted rr33yo this moring in the tunnel off castlehill rd onto penno rd, sau sticker, car sounded nice going through the tunnel.
Yay spotted :) i lovvve that tunnel.. what were u in mate?
Well, you know what they say.. If you can't say anything nice don't say anything at all...
KIDDING..
Nah looked pretty clean and sounded alright.. You need to rub that silly "drag/race number" off the window.. I can't stand that on cars..
Haha I was right behind your mate at the counter I was going to go over and say hi after I paid (I was just in my daily) but you guys left.
ahh i was in stealth mode my friend...in my work ute with mower on the back :)
also spotted a black na 33 leaving maccas at dural last night....i gave a little flutter as i went past when u were turning off (if your on here)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
