Spotted a nice white R34 at work this morning and had a chat to the chick that owned it.
Advised she was also a forum member, nice to meet you.
Nice to meet you too! Very nice car :-) Hope to catch you around the office or possibly at an event.
Spotted a bayside blue R34 Vspec II with what looked like LM GT4s but with Volk stickers at the Royal National Park yesterday. Very clean car (very young driver too! I'd have loved to have had an R34 at that age, lol).
Saw 11ty Skylines today in the Shellharbour/Albion Park area.
Black/charcol 33.
Black 34 sedan with pink plates.
Silver 34 sedan.
Silver S2 33.
White S2 33 (snapped photo).
Silver 33.
I think that was it.
I see so many driving past but don't know if anyone is from the forum, one white gtr I've seen drive past me twice now around the liverpool area
Might have been me. White LMGT4's?
Saw the same white r33 this morning on the m4 with green p plates after 5:30.
Also saw a silver r33 this afternoon around 2:30 on the Great Western Highway near Colyton. Nice car! Sounded mean as it zoomed past. Hope I didn't come across rude to anyone by not waving. I have been off in my own world all day.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
