I saw an R33 last night UFO 033 (I think) on Windsor road... I was in the 4 door at the lights.
Was that your mate in the Lancer? I heard this thing revving next me but I just thought nah not going to bother but the little thing took off pretty hard, would of been a good run after all...
Nice 33 you got there shooting some pretty mean flames too...
Isn't that Neil ????
r324d,
what area of sydney are you in - i've got a 4 door as well and never see any getting around my area
i see plenty of 33's on canterbury rd - black 2 door with DAMSXY plates, a white stock looking 2 door that always seems to drive faster when i get close in traffic & a black 2 door with chromies that was bought from an import place in canterbury
there is a very std looking black 32 coupe i see near the church st park in newtown. not sure if he is on the forums tho.
i'll never get spotted as my car blends into traffic quite well. its a nice change after my old car
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
