That would have been Ian (aka "StageIan") in the red Stagea, Christian.
I see this car all the time. Does it have a black front bar? I saw it the other day parked outside of Hardware and General in Brookvale, and then again out the front of my work at Neutral Bay. And I think i've seen him in Seaforth where I live too.
I spotted a white stage C34 the other day as well in Neutral Bay on my way home from work, that has a SAU sticker on the rear quarter window. Looked like an Asian chap driving. Gave the wave, but I don't think he saw me.
Cheers,
Shazza
Edited by XS80ST
Could it be love?
perhaps, (no homo)...
what is with Skylines, I don't think they're that sexy looking but I'm obsessed with them.. (R35 R34 GT-R excluded, because they're sexy looking)
Nah Gibbon sorry to burst the bubble but these were parked at the same place same time.
Bummer.
OT: same day spotted and gave big thumbs up to a gunmetal 33 and received a big thumbs up and a grin back
headed west on the M4 at about 1:30ish.
Cheers,
Shazza
It does, yep.
Indeed it does have a black front bumper, part of a new kit he's slowly piecing together as funds (and time) become available.
BTW, Stagea spottings have their own thread here: http://www.skylinesa...pot-the-stagea/ - that way if you see someone and want to know if the spotted you, you'll know (assuming they haven't posted here).
I spotted two V35s tonight, one a black coupe, and one was a silver sedan. Both on Pennant Hills Road, if I remember correctly.
Spotted Black R34 XMY-34X running Starcorps I think on Parramatta Rd, go right down Woodville Road a few days back. Whoever you were, I wanted to wave but was too shameful to do so in a silver Corolla :closedeyes:
last night saw heaps of lines in the CBD, sydney.
one black one 25GT, with green p plates sounded so weak (or...harsher word is gutless) (no offence)
silver 33...
black 33 with mesh wheels
probably one or two more can't remember now - not a single wave though.
Just spotted an R34 GT-R (either very dark silver or gun metal grey) about to be loaded onto a tow truck. Was about half past midnight, near the intersection of Kissing Point Rd and Silverwater Rd, Dundas area.
(null)
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
