Anyone who's been "spotted" on this thread and has had to use it as an alibi (of innocence)...
should fess up here right now!!!
jk
I wonder if this will hold up in court ... Haha thanks Terry.
Spotted a gunmetal R34 four door turning off Johnson Avenue onto the Prospect Highway, then turning into the industrial estate in Seven Hills about 4pm, then about an hour later spotted FLN75S (dark blue R34 GTt) heading in the exact opposite direction - from Prospect Highway then onto Johnson Avenue.
That would be me, heading home from work.
I knew I recognised those plates. :)
I was in the green Stagea.
Just spotted a white R34 GT-R with black bonnet in Blacktown, plates were FR34ME or similar.
(null)
F34RME*
Have seen him on these forums or JDMST I think.
Spotted a White 34 GTR with standard gov plates at around 12pm at Canley heights, parked near Caltex on Cumberland Hwy. I was mirin but man, whoever owns it needs to clean the rear. Biggest exhaust fumes stain I've ever seen, right to the top of the tail light!
Gunmetal 32 (DFT-32R) cruising with me in my bangin' Passat from Chatty to Allambie this arvo. I think he thought I was scoffing at it. I was actually digging it.
2 days in a row I've spotted a white r34 gtt coupe with black rims turning onto forest road next to shell rockdale/bexley, he's been going up and down my street quite often lately actually, just wondering if your on here, thanks.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
