I had a black R34 GTt parked in my street earlier in Toonie, almost directly across the road from my house. It had a kit on it and black multi-spoke wheels, not sure who owns it and didn't get a chance to check it out.
Saw this car again yesterday, I think it's just a non-turbo GT, not a GTt. Young dude driving it.
Today - Bayside Blue 34GTR with LED tail-lights on Quakers Hill Parkway around 7-730pm
Also saw him on Sunnyholt around this time. Gave him a thumbs up and he gave me a wave back as he turned off onto Old Windsor
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
