Spotted: A white R34 GTS25T in Macquarie Shopping Centre carpark !!
You got guts, ill give you that !!!
why does he have guts? wats wrong wit parking at Macquarie Shopping Centre? lol please let me know since i alwayz park my car there since i go to that uni.
btw how da hell do i quote someone now? the button is gone
Macquarie Shopping centre is a well known place for performance cars to disappear, very very quickly. Even with the best alarms and immobilsers. Since i found that out i never go there. Also the fact it is a poorly designed shopping centre.
Quote button is still in the same spot
ahh crap
r u serious? i go uni there as well...
Thanks for the advice, i aint parking there no more
last time i think i saw a car get stolen right in front of my eyes. Some bomb, but i didnt realise those guys were stealin the car after they left. It took them less den 2mins -_-;
the security @ macquarie dont do shit either....i got a mate with a skyline...flattened his battery, push started it down from the movies 2 the bottom...couldnt do it, so me and a mate rock up in a 1960 breaten up pos volvo and jump start it....security must have gone past 3 or 4 times from the top of the ramp to the final jumpstart...no qustions asked
sorry 2 post whore
It all depends on how fussy you are with your skyline, i suppose..
For me - ive heard too many horror stories about car parks (not only thefts, but scratches, trolley bumps, etc)....
And as a result i wouldnt take my car to a shopping centre carpark...(unless they had valet..)
Standout blackspots are Macquarie shopping centre, Bankstown Square and Westfield Parra & Miranda..
guilty, yeah thats fine, would be theives look at it and think mehhhh stands out too much :D
gizmo, no offence but coming from the central coast you sound so versed with sydney car parks...your knowledge of these vulnerable car parks stems from...???
Hehehe...what makes you think valet parkers would treat your car any better? :D
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
