Spotted: A white R34 GTS25T in Macquarie Shopping Centre carpark !!
You got guts, ill give you that !!!
why does he have guts? wats wrong wit parking at Macquarie Shopping Centre? lol please let me know since i alwayz park my car there since i go to that uni.
btw how da hell do i quote someone now? the button is gone
Macquarie Shopping centre is a well known place for performance cars to disappear, very very quickly. Even with the best alarms and immobilsers. Since i found that out i never go there. Also the fact it is a poorly designed shopping centre.
Quote button is still in the same spot
ahh crap
r u serious? i go uni there as well...
Thanks for the advice, i aint parking there no more
last time i think i saw a car get stolen right in front of my eyes. Some bomb, but i didnt realise those guys were stealin the car after they left. It took them less den 2mins -_-;
the security @ macquarie dont do shit either....i got a mate with a skyline...flattened his battery, push started it down from the movies 2 the bottom...couldnt do it, so me and a mate rock up in a 1960 breaten up pos volvo and jump start it....security must have gone past 3 or 4 times from the top of the ramp to the final jumpstart...no qustions asked
sorry 2 post whore
It all depends on how fussy you are with your skyline, i suppose..
For me - ive heard too many horror stories about car parks (not only thefts, but scratches, trolley bumps, etc)....
And as a result i wouldnt take my car to a shopping centre carpark...(unless they had valet..)
Standout blackspots are Macquarie shopping centre, Bankstown Square and Westfield Parra & Miranda..
guilty, yeah thats fine, would be theives look at it and think mehhhh stands out too much :D
gizmo, no offence but coming from the central coast you sound so versed with sydney car parks...your knowledge of these vulnerable car parks stems from...???
Hehehe...what makes you think valet parkers would treat your car any better? :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
