Spotted: This morning 9:10 am Duncan + Kell running late for work in the tree-fiddy. Duncan was waving his arms around alot as they drove up goulburn st. :)
Duncan, you are a late, late man- nearly as late as me!!!
Richard
hahah cutting it *very* close these days, its gets harder to get out of bed as it gets colder lol
I didn't see the gtir tho?
Nah, didn't pick it up 'till last night, plus I was getting a lift to work (I generally commute via pubic transport). In a blue camry - fanging machine...
Richard
saw a black R33 (ML3107) on Waterloo Rd with SAU sticker :)
would've waved but you were two lanes over
That would have been Talej on the forums.... He works at North Ryde, and mate of mine.
Step forward Talej and take a bow :headspin:
Double whammy today....
Saw Abo_bob.....on oxford st...got freaked out when the windows came down to reveal a white guy :rant:
and literally 30min later saw moanie at strathfield....
and spotted a white 34 in blacktown....might have been GTR cause those rear gaurds and wing were pretty chunky...
LOL!!! that was you shonen? why didn't you say something!!! you looked at me like you thought i was a freak for saying hi! lol! well firstly i thought you put your window down because you thought you knew me! then when you realised you didn't i could see you thought i was strange!!! slacko!!! :rant:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
