Wow, that really is the worst graph on an SR I can recall seeing for the GTK! Yikes...won't be entertaining that idea that's for sure.
Thanks for all the graphs and info Trent. I really thought the L2 would have run out of puff by then. So you'd recommend it over an 8cm T67 then, considering the extra capacity?
  • Replies 76
not exactly, just saw some flaws in others comments on the L2, thought id clear it up.
My choice would be Hks gt3037s around the 0.73, or T67 8cm.
Any particular reason for the T67 over the L2 considering the power potential of the L2? Or is it a matter of a bigger gain without much tradeoff?
He's a blurb I found on the BWs200 vs T67...scroll down the link:
http://www.turbo-kits.com/s200_turbochargers.html
and dyno comparison
Edited by juggernaut1
Hey Trent i have a question about using a TD06S-L2 20G on a RB25, I have found some graphs and they show that with the 8cm rear housing they choke the boost up top (Boost drops off from 25 PSI to 18psi). Do you have any suggestions on getting it to hold boost through to the redline.
I have also seen a graph of a T67 8cm and once again in the top end it was dropping off from 19psi to 14psi. It's weird because on the RB's the 8cm housing chokes them above 300kw but with the SR's they hold boost.
I know that they are a larger engine but flow is power so technically a 300kw RB will be flowing the same air as a 300kw SR so they should choke at the same power.
Also do you have any graphs of an L2 20G 10cm on a 25?
TD06S-L2 20G 8cm
Edited by D_Stirls
TD06S-L2 20G 8cm
too small and never hold boost. The 10cm in not available in the L2 trim. We use the t67 8cm on some rb25's (decent mid) but they are restricted hevily up top, 10cm T67 is the go for rb25
There is a company that is making Greddy copy versions of turbos that has designed a T3 10cm housing for the L2.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
Looking at the Greddy turbo data sheet that was on the other page the inducer and exducer size is the same on the 06s-L2 and the T67.
EDIT!!
Sorry the data sheet was in another topic,
Here is it;
http://www.skylinesaustralia.com/forums/post-a251041-
I was thinking about extrude honing a 8cm housing to an in between size.
Edited by D_Stirls
Have you seen these results?
This is an S15 engine with cams but a standard bottom end. That is the best result in terms of response I have seen from a 3071 turbo, 20psi@3600rpm and peak power of 285rwk@20psi. Throw another 4psi and it should hit 300rwk. You cant want much more than that!
Silvia NSW
We just finished building a rb28 with a GTK 850 and it is laaaaaagggy. We made more power and response with twin GTRS's(2871R) They are designed for huge boost. The turbine design gives the same impression. So I would pick the smallest you can to JUST achieve the power less your after.
My pick for an SR is a V band .63A/R GT2871R, external gate running 1.7bar. We made 299rwkw and very very little lag. Fantasticly broad power range.
For a rb25 3071R is the go.
I'm sure disco will say the same. and he knows....=)
Edited by BoostdR
My friends RB25/30 will be getting tuned this Thursday. Has a GTK1000 strapped to it.
Built engine
Poncams
CR 9.5:1
E85
On its run in tune its making 11psi by 4200rpm however rev limit was capped at 5000rpm :)
Will post results soon.
Silvia NSW
i'll chasse some 3071 sheets too.
Edited by URAS
Ah , no . If you want 300 plus Kw the one to have IMO is a GT3037/GT3076R as URAS mentioned .
For whatever reasons the GT3071R has not really shaped up to be the GT3076R's little brother as in the 1000 revs lower boost threshold that a few mobs claimed when they first hit .
Without being blunt I think the original poster has to look at the final result rather than thinking that if I spend a big wad of cash I have to have a big maximum power number to justify it .
IMO there is more to be gained from properly sizing and tuning everything than the just 40-60 Kw more . Ideally you want the thing to be torquey/free revving/good throttle response/good turbine response/minimal restriction .
This is why I'd start with the quad throttle inlet system , Nissan did it to the GTR (6) and GTiR and they would not have bothered if there was nothing in it .
Also you don't want to confuse throttle response with turbine (turbo) response because they are two very different things .
What the individual throttles do is make for a rapid pressure rise in the inlet manifold (up towards atmospheric) which brings the dynamic or effective compression ratio up quickly too . When you have a single throttle/plenum manifold you have four cylinders all demanding air from the one source so the pressure and dynamic CR transients will not be as fast .
ITB's also allow you to run warmer cams than the single throttle ones and not get the reversion or hot cam cranky spluttering nonsense . I know that cam profiles and compression ratios are set for a reason but go look at std cam specs for say an S13 SR20DET and a GTiR SR20DET , ditto R33 RB25DET and RB26DETT .
Geoff Raicer has worked with quite a few different manufacturers toys but I think the faves might be Nissan Mitsy and Subaru . You obviously know he does tasty bits for SR20DETs so you could do worse than to explain exactly what you want to do and ask him how he'd go about it . He'd know what spec engines he's had his exhaust manifolds on so he should be able to give you his personal findings .
At this point in time I know he has been building manifolds to take the current Mitsy Evolution 10 turbos and importantly Garretts upgrade twin scroll GT3076R turbo for the Evo 10's . It's not impossible that he'd think a TS manifold made to suit that turbo would work well . The only issue could be that there have been some teething problems with the Garrett/Mitsy TS integral waste gate turbine housing but when they fix it the theory is will cream every other single scroll GT3076R out there and not be laggy .
In the past some of the more successful GT3037 (satisfied) SR20 people in the US have used HKS's 0.73 A/R turbine housing (T28 flanged non gated thing) with good results . Garrett's T3 flanged GT30 turbine housings are either side of that A/R size at 0.63 and 0.82 , the largest 1.06 one would be too big IMO .
Again no offense but trying to compare a Silvia to say an Evo 6 is like comparing apples to cricket balls . The Evo has short diffs and close ratios big IC/TS turbo etc etc etc . There will be limits to how much power a Silvia can put to the tarmac and making much more than that would be an exercise in frustration I think .
Your calls , cheers A .
Totally understand what you're saying, and I do agree with you. I'm not just looking for a total power figure, but I do know whereabouts I want it to be. Adam in his RB25 Skyline track car doing the rounds here in vic puts comfortably more than 300rwkw's to the ground and I see no reason why I shouldn't be able to have a turbo setup with a nice linear response put down somewhere in the high 200's, even if it is after aero work and more suspension tuning. I simply want the potential and do not want to change setups again. I'm not chasing a power figure as such, but rather using it to define the size of turbo whose potential I will find acceptable.
I'm not going to be changing my inlet plenum anytime soon, so I'll see how it goes. My cars powerband with the stock capacity was acceptable before, but not perfect so I'm used to a car that operates in a high rpm powerband, but I also know I can get more power and better response with another setup. I do circuit sprints, not door to door racing, so the cut and thrust of traffic is not a concern.
Also, I'm already speaking with Geoff, and he recommended the 3071R setup after taking a look at my specs and considering my use for the car. We're also discussing the BW options and he's keeping me updated on progress with the new range. Geoff also liked the look of my CPC plenum, so we'll see. I'm just obtaining some quotes at the moment from the sales department.
Please don't see this as ignoring your advice, but I have a fair bit of experience with the car on road and track (have had it for 6 years) and different setups so am not throwing up pie in the sky options without taking into considerations the pro's and cons. I'm not someone saying I must have 300rwkw's because that will make me fast, so perhaps I'm not articulating well enough. I'm just considering all options to work with my existing engine setup and I guess this is why I have this thread in the first place! :banana:
Troy: May do mate! Bu I can't have your skill outshining my engine power...
Jugg: Thanks for that. Interesting reading and would be good to see a few more comparisons. BW is still a really big consideration, depending on when Geoff decides/is able to test out the smaller range of T3 divided. They're cheap too, which is an added bonus and the results thus far are pretty promising for the rest of the range.
BoostedR: Do you have a dyno sheet by any chance? And is that a full V-Band system (ie Tial exhaust housing), or just for the dump pipe?
SRS13: Yeah I have mate, and it's bloody impressive to say the least. I think I'd go the twin scroll version if I were changing manifolds as well though, just for the increased transient response. But it is an option if I were to just change my manifold now, and then move on to a 3071 down the track for cost purposes.
Please don't compare evos and silvias, it's insulting to those of us who can steer and modulate the throttle and brake.....
I'd be going a 3076 on your car phunky. Possibly look at reducing the duration on the cams while keeping high lift to promote better low-mid range as you have the big valves already to keep the top end flow. Go the TS housing and manifold if you feel that way inclined, on the plus side it'll soften the torque hit as the turbo gets going (though the 2.2 will do that a bit anyway by bringing it on in a more linear way) and make it a bit easier to drive out of corners.
Thanks for the advice Dave. I contemplated going the 264/272 setup and regret not doing it a bit now... But I may change to that if I'm not happy with it. Softening the torque hit with the TS is what I was thinking, as I think that part of the reason why I've always achieved quite good drive out of corners with little wheelspin is I'm using an old HKS T300 turbo which is not BB. The added lag induced could be a contributor... though I could be way off :cool:
Thanks for the advice Dave. I contemplated going the 264/272 setup and regret not doing it a bit now... But I may change to that if I'm not happy with it. Softening the torque hit with the TS is what I was thinking, as I think that part of the reason why I've always achieved quite good drive out of corners with little wheelspin is I'm using an old HKS T300 turbo which is not BB. The added lag induced could be a contributor... though I could be way off :blink:
the T300 is a bit how-you-going when compared to the later stuff, i did a few t300 ca18's years ago and they definitely needed a fair peddle to get going :cool:
The 312rwkw l2 i posted the graphs for ran 264 inlet and 272 exhuast
Yeah, it's certainly not the most responsive of things but has held up pretty well for me thus far. I've been hanging to get i tuned with the 2.2 as we were only able to do a run in tune before the manifold gave way, but with that it was doing 225rwkw's at 14psi and was making 20rwkw's more at 3900rpm than it was with the 2l, and 20rwkw's more at 3200 despite the big cams. I'd like to find out what it's limit is, but some niggling problems have kept me from it so far.
I remember having Athid's 180 on the dyno and mine on the same day, and the curves were quite similar and power similar too. Interestingly I'm making 30rwkw's more at 3910rpm than the 312rwkw L2 dyno with the 264/172 combo, but Athid's S15 dyno creams it at the same RPM by around 30rwkw's!
I am with Dane on this one. No doubt Emo drivers are spoilt with ass tickling dildos, fish finders and electric tooth brushes doing all the stuff the rest of us require a little grey matter for. But at 260rwkws my car isnt challenged for traction at all. And only recently did i really get some decent suspension under my car.
i see no reason why a decent S13 chassis cannot handle 300rwkws. I am hoping to be up around 280-300rwkws by years end and still think with decent susp and tyres its not going to be as lively to drive as i had hoped. Adams R33 that was referred to was what i wanted my car to drive like, unfortuantely i wont have the extra 1oorwkws required for that sort of thrill seeking :ninja:
gtk on sr loll u sure it wasnt a civic?
If it was a VTEC engine running that turbo, it could have been more at the start and even more at the end :ninja: The peaky thing is for when they don't have a turbo doubling (or more) its effective displacement :)
+1 for twin scroll GT3076R!
Edited by Lithium
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
