  • Replies 477
Well I have started cutting DI-NOC as you can see by the wood grain iPhone covers, isn't simple and takes a bit of time but perfect cut.
This stuff is as thick as the carbon but smoother so trying the carbon in next few days, let the fun begin.
Edited by Guest
  • 3 weeks later...
Just had a thought of how cool my cordless mouse would look for my laptop. Feel stupid asking this from the amount of stuff iv seen wrapped here... Is it possible? with the fine button lines n all?
Show me a pic and I'll tell you :whistling:
Here's one for you that is a bit different............. The start of a large Jet Ski.
looks good,
well done with the curves, got a lil project of my own some of you might be interested in, will post pics soon
Link:
http://www.maplin.co.uk/images/Full/a84hx.jpg
If you thinks its easy to do ill give it a burl, would look good i think, then i'd like to put a small GTT logo where it says logitech.
Are you wrapping the whole thing or just a certain part?
But I think it shouldn't be too hard as long as you have patience. PM ne if you need a little sheet of the vinyl.
Hey mate, saw your'e in Mordy, I live pretty close :D. Really interested in getting this done for my head unit surround thingy and some other places. Since i'm a poor P-plater price is a big deal :D. I cant send a pm because i'm still new sorry.
looks good,
Thanks, second one came out a lot better as you can see and Version 2.0 of the iPhone cover is on the streets.
Also got a complete R33 trim set to use on an exchange basis over here as a pain rushing.
Hey mate, saw your'e in Mordy, I live pretty close :). Really interested in getting this done for my head unit surround thingy and some other places. Since i'm a poor P-plater price is a big deal :D. I cant send a pm because i'm still new sorry.
No problem mate, gimme a buzz or sms on 0434 502 855 :D
Thats the bees knees, nice work guys.
I'm trying to find this stuff in matte black, no luck so far. :thumbsup:
I can get hold of it in Matt Black just depends on what you want it for as to worth getting or not.
driftt or charles, could you do a GTR plenum??
Yeah easy just need one to give it a go.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
