Speak to Daniel @ Platinum PPI
http://www.platinumcarsecurity.com/
http://www.platinumcarsecurity.com/Contact.htm
He's got a lot of good options and he's very good at making tricky unique installs.
Thanx heaps for this info mate - i trust your judgment with referring this guy, the worst thing about security systems installations is taking it to some guy who installs your security system who in the mean while takes down all your info and then in a couple of weeks your car is stolen easier then a grandmas purse! my mechanic has told me some really horror stories! i he reasonably priced?
DON'T GET MONGOOSE!!!!!
everyone has that alarm, stealing a car can't be anymore simply, just rip off your box and remote and plug and play into a Mongoose Equipped car!
Seriously it's a great alarm, but look how easy it is to pinch a car
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
