Spotted a shit load (and I mean a shit load) of Skylines in Civic/Braddon last
night (JohnnyR31 & I went for a bit of a drive)
Among them.....
Black R34 25GT-t sitting in the servo in Braddon
White R32 GT-R in front of the R34
White R32 GT-R came into the servo for a few minutes
Red/Silver R31 Silhouette parked in carpark behind Caltex servo
Blue R32 GTS-t with rego plates 'MARK' came into the servo
Silver R33 GT-R at hospital traffic lights
Gunmetal grey R33 GTS-25t went through the Hindmarsh Dr/Melrose Dr traffic lights a few times
White R32 GTS-t at the same set of lights
White R33 GTS-25t with black wheels again at same lights
And today in Yarralumla a black/gunmetal R32 GT-R, I gave a little wave & I think I got a nod back
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1008940
spotted myself getting own3d this morning by a new worked SS ute.....unbeleivably pissed off, it was neck and neck from the lights but we got to a round about and he had the inside lane so i had to slow down alot more and turn more being on the outside. im so sick of running stock boost!!! i would have drilled him running if i was running anything over 10pound, i'll have to be pateint till i get my ebc and fmic i guess.
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1011091
What? That's outrageous behaviour and unacceptable.
You mean you didn't draft him through the roundabout? Should've tucked in behind and used revs to punch out ahead through the other side...heh heh bring on the boost.
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1011815
hot driver? nah couldnt have been supafly, cause i wasnt driving his car on sunday
:wassup:
while were bringing up old spotteds, i spotted a white R31 on sunday just after dropping angus off in chifley. it broke for a roundabout and the left taillight lit-up saying skyline, and the right one said silhouette(sp?) looked cool, even though i dont really like R31's
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1012745
:wassup:
That's a friend of mine and angus'. That Silhouette actually goes very hard for what it is...... just something about it
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1013628
Spotted a couple of flash skylines today,
A black R32 with fire details painted on the front end driving through Kaleen
A silver R33 with stripes like that of the R34 in 2 Rice 2 Furious in Dickson
https://www.sau.com.au/forums/topic/30059-spotted/page/59/#findComment-1013856
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
