Spotted thismorning about 7am going southbound on the parkway a nice white R33 GTR, and this morning about 10 saw a nice Gunmetal R32 GTR outside the Canberra times building on Isa St, very sweet, i think it's the same one you saw, SkyGTRLine. it had gold mags
https://www.sau.com.au/forums/topic/30059-spotted/page/198/#findComment-1541916
hey hey hes prob feeling very dirty right about now about too so dont pick on him.
hhhhahahahhahahhah sorry guss, hey we have all dont it so many times before, what a shit.
Edited by race_snooze
https://www.sau.com.au/forums/topic/30059-spotted/page/198/#findComment-1542499
Spotted: Black series 2 R33 GTS-t parked on Reed street in Tuggeranong about lunchtime today. I know it’s someone on these forums as you had a SAU sticker on the back windscreen, just like mine!
That would be me. Saw you pull up and leave. I was working in Cartridge World. Would have said hi or something but didn't notice the SAU sticker till you left. You made my car look a bit shabby parking infront of it! :( Looks sweet.
Don't spose you know a guy named Damien by any chance? Drives a yellow 300ZXTT?
https://www.sau.com.au/forums/topic/30059-spotted/page/198/#findComment-1542599
bahaha poor gus actually poor little red car hope you got some left otherwise that will be a pain to drill em out  :D
trust me, they dont drill put after they've been welded :D
seriously, i dont know how it snapped, it wasn't even tight (the bolt) and it just snapped off....damn i felt bad lol
https://www.sau.com.au/forums/topic/30059-spotted/page/198/#findComment-1542728
That would be me. Saw you pull up and leave. I was working in Cartridge World. Would have said hi or something but didn't notice the SAU sticker till you left. You made my car look a bit shabby parking infront of it!  Looks sweet.
Ah nice, I could see someone looking at the car from inside Cartridge World and thought it might have been the owner. I would have come in and asked but was already late for getting back to work! Next time if I see your car I will drop in and say hi :D
Nah I don’t know the owner of that car, at least I think I don’t. BTW nice looking 33 mate!
https://www.sau.com.au/forums/topic/30059-spotted/page/198/#findComment-1543815
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
