spotted a very nice looking white s2 R33 at the intersection of launceston st and yamba dr. gave a wave. anybody from here?
Was it me?? Did someone actually see me? ive been waiting a long time for this
PLEASE BE ME
https://www.sau.com.au/forums/topic/30059-spotted/page/223/#findComment-1666872
Spotted/followed dj hatton (unless there another blue one) in QBN on friday night.... i mean saturday morning.
Of all times and places for two cars to end up following each other hey? Where you dropping off friends? I was.
https://www.sau.com.au/forums/topic/30059-spotted/page/223/#findComment-1666970
PLEASE BE ME
sorry mate, im pretty sure that the front bar was different. it might've bee you though, i didnt get a real good look at the car. were you leaving woden at about 2pm ish?
https://www.sau.com.au/forums/topic/30059-spotted/page/223/#findComment-1667296
OH NO
I was in Woden a bit later than that i think
DAMMIT
https://www.sau.com.au/forums/topic/30059-spotted/page/223/#findComment-1667415
