I dont know if you know Leigh but I used to work for BMW and we had all sorts of problems with the 850i's... They werent the best built beemer ever thats for sure.
They also didnt sell very many because of the price tag, they were a BIG flop for BMW and I think they lost a lot money out of it too.
Nice cars though and they go pretty good (even though they weigh 2 tonnes). :kiss:
I didn't know that, you would have seen some awesome cars then. I just thought it looked funky i have not really seen anything like it on the road before. Sounded pretty mean when he put his foot down, It was a black one by the way.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345884
i have seen that one around also.
The M1 brings back memories - my uncle runs a garage in Zurich and he got one of these in by chance for a checkup (not in racing livery of course):
i only just noticed now that the front of the 850 looks like it was lifted from the 1972 bmw turbo concept, is that right mick?
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345924
Yeah, there are 2 black ones geting around the ACT I believe... They sound mean when you put the foot down because they have an "active" exhaust, which just means that there is a butterfly in each pipe that opens right up when youre into it and closes slightly when youre cruising to help save fuel, which you'd need to do when youre driving a 5 litre V12... They did have 300bhp and heaps of torque standard though, so they got up and moved pretty well.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345948
Looks that way doesnt it...
Have you guys heard about the M8 concept that BMW was going to produce?
They scrapped it but it was going to be based on the 8 series but using a wide wheel base, lighter body and chassis but it was going to have a 5.7 litre V12 producing 550bhp! Niiiiiice.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345973
vailside on monday night, all from a text message from him saying I see you lol.... Snow Patrol concert.
Haha, yeah, that was a weird coincidence! Saw you right in front of me and it was too load to yell, so the text made sense, lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3347426
I've seen one of those BMW's in woden, 840 i'm guessing. I do remember it stood out but didn't realise it was anything special...
Spotted a silver R32 could have been a GTR on northbourne this arvo at around 4.30ish. Opposite side of the road so couldn't wave.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3347905
The rain came and went before the tow truck showed up. It took about 3 hours to get me home as because the transfer case was shagged, he had to use the 'dolly' as he wasn't driving a flat bed.
What a mess, there's a gaping hole in the transfer case and chunks of stuff everywhere. I have my old auto gearbox and the transfer cases look identical so hopefully I can just swap them over and get back on the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3349944
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
