I dont know if you know Leigh but I used to work for BMW and we had all sorts of problems with the 850i's... They werent the best built beemer ever thats for sure.
They also didnt sell very many because of the price tag, they were a BIG flop for BMW and I think they lost a lot money out of it too.
Nice cars though and they go pretty good (even though they weigh 2 tonnes). :kiss:
I didn't know that, you would have seen some awesome cars then. I just thought it looked funky i have not really seen anything like it on the road before. Sounded pretty mean when he put his foot down, It was a black one by the way.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345884
i have seen that one around also.
The M1 brings back memories - my uncle runs a garage in Zurich and he got one of these in by chance for a checkup (not in racing livery of course):
i only just noticed now that the front of the 850 looks like it was lifted from the 1972 bmw turbo concept, is that right mick?
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345924
Yeah, there are 2 black ones geting around the ACT I believe... They sound mean when you put the foot down because they have an "active" exhaust, which just means that there is a butterfly in each pipe that opens right up when youre into it and closes slightly when youre cruising to help save fuel, which you'd need to do when youre driving a 5 litre V12... They did have 300bhp and heaps of torque standard though, so they got up and moved pretty well.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345948
Looks that way doesnt it...
Have you guys heard about the M8 concept that BMW was going to produce?
They scrapped it but it was going to be based on the 8 series but using a wide wheel base, lighter body and chassis but it was going to have a 5.7 litre V12 producing 550bhp! Niiiiiice.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3345973
vailside on monday night, all from a text message from him saying I see you lol.... Snow Patrol concert.
Haha, yeah, that was a weird coincidence! Saw you right in front of me and it was too load to yell, so the text made sense, lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3347426
I've seen one of those BMW's in woden, 840 i'm guessing. I do remember it stood out but didn't realise it was anything special...
Spotted a silver R32 could have been a GTR on northbourne this arvo at around 4.30ish. Opposite side of the road so couldn't wave.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3347905
The rain came and went before the tow truck showed up. It took about 3 hours to get me home as because the transfer case was shagged, he had to use the 'dolly' as he wasn't driving a flat bed.
What a mess, there's a gaping hole in the transfer case and chunks of stuff everywhere. I have my old auto gearbox and the transfer cases look identical so hopefully I can just swap them over and get back on the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/435/#findComment-3349944
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
