Spotted a white 33 GTR idling away out the front of a house in Jerra' that has many top notch cars in it's garage...and no; I'm not going to say exactly where!! Rego' started something like "PR...", and apparently had a very 'safe' tune, judging by the exhaust tip and it's surrounds. Anyone on here?
https://www.sau.com.au/forums/topic/30059-spotted/page/462/#findComment-3633268
I wanted to say hey to the Dark Blue/Purple R33 Series 1 (with the ugly back bit, 4 door I think) Driving in chatswood, Pacific Highway SYDNEY yesterday at about 6:30 last night.
Was great to see you, every skyline in that model I see looks like shit! You have raised the bar for owners that is the cleanest, nicest 33 ive ever seen including series 2 (GTRS excluded lol)
cheers
https://www.sau.com.au/forums/topic/30059-spotted/page/462/#findComment-3637159
I was in Sydney for the Iron Maiden concert over the weekend. Saw plenty of Skylines in my 2 days there.
Also saw a 360 Spyder on Parramatta Rd, which by the way is quite possibly the worst paved road I've ever driven on.
https://www.sau.com.au/forums/topic/30059-spotted/page/462/#findComment-3637624
spotted black 33 in the city
and a white 32 gtr on hindmarsh (Fyshwick side) around 11am
Spotted a countach on the back of a truck in fyshwick aswell
white 32 sounds like me, rockin up to work nice and late as usual.
https://www.sau.com.au/forums/topic/30059-spotted/page/462/#findComment-3640972
spotted a white R34 outside dyno tune in belco around 7:30 tonight and a black R33 just then in higgins
white R34 belongs to my mate, he just got it and was getting new coilpacks put in. very nice car.....
D.
https://www.sau.com.au/forums/topic/30059-spotted/page/462/#findComment-3642746
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
