Spotted a Blue R32 in city west just after 5pm. Gave you the thumbs up on Barry Drive, not sure if you saw me. I was driving an 08' Corolla.
Probably was me, although only saw someone in a white prius wave at me, wasn't you? Didn't see you on barry drive though sorry.
https://www.sau.com.au/forums/topic/30059-spotted/page/488/#findComment-3959997
It's even nicer inside...Sorry for the av' photo; as best I could get with the phote I had!
It was interesting how many people missed one of Nissans' greatest, being the amazing black NuR Spec, sitting right there in front of the 35. I'm probably biased towards the 34, as good as the newie is. There was much interest from all types, old and young, male and female, in the new supercar. Talking with the drivers, there was much to like about the new car! There was an interesting part in the boot that wasn't to do with the R35, but that's another story for later...
Edited by LTSJayce
https://www.sau.com.au/forums/topic/30059-spotted/page/488/#findComment-3960681
Red 33 near brand depot around 12pm
Think it was Bluprints 31 on Northbourne, near Barton Hwy lights
Also spotted some hilarity near dickson shops. Was stopped at the lights and i saw this old asian man pointing his camera in my direction from the side of the road, i thought it was funny but noticed the angle was just a bit off so i look past my car to where he is looking and see a group of 13 year old netball players in their short skirts.
https://www.sau.com.au/forums/topic/30059-spotted/page/488/#findComment-3961126
if it was thursday i was there but since it was posted yesterday i'm guessing it was yesterday
https://www.sau.com.au/forums/topic/30059-spotted/page/488/#findComment-3962577
couple of mates and i saw it pull up, very nice!
i was there :) was in gus' having coffee and i almost couldnt believe it.. i saw the NUR spec there last week as well.
The was a dark silver r35 at autosalon, one of the nicest looking cars i have laid eyes on
https://www.sau.com.au/forums/topic/30059-spotted/page/488/#findComment-3965138
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
