saw gtrkat and her hubby in their audi at the lights of ginnenderra and GDE we waived and they waived back.. also saw frink and blueprint at the lights on hindmarsh and tugger pkwy i didnt realise it was them until we were around the corner. i was in ZCR's car but seeings as he hadnt posted yet i thought i would..
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4255604
Haha, thank god for that then....
John just rang to tell me that I've lost 30kw's somewhere though :-(
dang.. he rang me this morning to tell me that i have severe wiring problems and that my rear muffler is fked.. looks like a fun day for john at torjan giving everyone bad news.. at least its getting fixed *fingers crossed*
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256280
Just got off the phone with John again... Turns out that my middle muffler is rooted and my rear muffler is probably gone as well. Would explain the random detonation that was happening.... Off to PowerTone in Fyshy for another legal cat back system.
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256324
me and bluprint spotted zane in woden last night around 7pm ish....
ya'll beat me to it! but yes, there was some spottage last night!
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256679
Yes I spotted a certain someone showing off!!!! ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256998
spotted a dark blue 32 or 33.. looked more like a 32 but you never know (it was far away and the dark colour hides the body contours.. thats my excuse)
it drove past my window in immigration belconnen about 3 minutes ago. it had rather large rims.. 18's or 19's
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258330
Spotted a White R33 heading along Hindmarsh towards Fyshwick at lunch time. Also a White R33 with a large bodykit on it in Fyshwick on my way to Harris Tech.
(Car's booked in tomoz to get my two new mufflers sorted, yay, hope it will be quiet enough for the police but loud enough for me)
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258409
did you see my car when you were out at trojan? im hoping that she is ok
looks as thought i may need a new exhaust as well.. might just put my pea shooter back in until i can afford it
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258642
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
