saw gtrkat and her hubby in their audi at the lights of ginnenderra and GDE we waived and they waived back.. also saw frink and blueprint at the lights on hindmarsh and tugger pkwy i didnt realise it was them until we were around the corner. i was in ZCR's car but seeings as he hadnt posted yet i thought i would..
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4255604
Haha, thank god for that then....
John just rang to tell me that I've lost 30kw's somewhere though :-(
dang.. he rang me this morning to tell me that i have severe wiring problems and that my rear muffler is fked.. looks like a fun day for john at torjan giving everyone bad news.. at least its getting fixed *fingers crossed*
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256280
Just got off the phone with John again... Turns out that my middle muffler is rooted and my rear muffler is probably gone as well. Would explain the random detonation that was happening.... Off to PowerTone in Fyshy for another legal cat back system.
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256324
me and bluprint spotted zane in woden last night around 7pm ish....
ya'll beat me to it! but yes, there was some spottage last night!
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256679
Yes I spotted a certain someone showing off!!!! ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4256998
spotted a dark blue 32 or 33.. looked more like a 32 but you never know (it was far away and the dark colour hides the body contours.. thats my excuse)
it drove past my window in immigration belconnen about 3 minutes ago. it had rather large rims.. 18's or 19's
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258330
Spotted a White R33 heading along Hindmarsh towards Fyshwick at lunch time. Also a White R33 with a large bodykit on it in Fyshwick on my way to Harris Tech.
(Car's booked in tomoz to get my two new mufflers sorted, yay, hope it will be quiet enough for the police but loud enough for me)
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258409
did you see my car when you were out at trojan? im hoping that she is ok
looks as thought i may need a new exhaust as well.. might just put my pea shooter back in until i can afford it
https://www.sau.com.au/forums/topic/30059-spotted/page/517/#findComment-4258642
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
