I can't believe you're posting on SAU only a few days after the new WoW thing came out. :(
I know!
Got Level 75 on Sunday afternoon though :banana:
To be honest, i came back cause i blew my Turbo on Thursday and was poking around to see what was what
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4266209
gungrey wingless r32 just drove past my window at work (ie up joynton smith drive past between immigration and the belconnen mall) must be kind of loud because i heard it over my music (headphones) and through the window.. the car looked mostly stock apart from the wingless rear end. i didnt get a long enough look (and only from the back) at it to decide if it was a GT/R or not
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4267471
spotted Shell this arvo heading into fyshwick turning on to Canberra Ave. hope i didn't chop you too bad when i merged! i was driving the white subie, which is why it probably looked really strange seeing some idiot waving at you in a totally different car!
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4273264
haha so it was you... I was fairly sure... yeh I did wonder who it was at first with just the arm, but then the head came out the window as well haha :D
No the merging was fine, I always leave a bit of space and let people in at that spot... cos I'm a considerate driver like that lulz
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4274531
Spotted an unmarked black VE SS ute stalking the dara formal last night ..massive cheers the random who knocked on the window and warned us
r33skylinegtst - I've seen a couple of new model lancers as unmarked cars lately, hubcaps and all haha
and followed a mint white 32GTR with gold Volks through fadden and lower chisho yesterday
https://www.sau.com.au/forums/topic/30059-spotted/page/519/#findComment-4277609
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
