hey kat does petes car have double clutch or anything like that?? or not performance enough?
spotted a pink R33 go past the tennis courts in tuggas...jsut down from maccas at the college...and a white one with a SSQ BOV boosting aorund the joint
I'm not sure... It's the frigging weirdest clutch I've ever had to use though.
https://www.sau.com.au/forums/topic/30059-spotted/page/525/#findComment-4319346
Rossco was that you that I saw driving out of Autotech this afternoon?? That was our S3, I was there dropping off my clutch :(
yeah still chasing parts for my defect the car is runnning like shit atm all in its rego spec iv lost 5-6 pound boost cause of the muffler thats on there atm soo gay na the guys at autotech have been chasing parts all of last week for me and this week
https://www.sau.com.au/forums/topic/30059-spotted/page/525/#findComment-4319742
It was me in coolamon court :) did you drive past just as i was going out of the dominos/car lovers carpark bit???
And it was me in the pink r33 in tuggers and my mate Reese (sexy33) was in the white one :D
https://www.sau.com.au/forums/topic/30059-spotted/page/525/#findComment-4320219
Nah I was drying my car in the carpark opposite Carlovers when you drove out of the Dominos carpark. You would have seen a red & silver R31 and a white Liberty with 2 blokes scratching their heads thinking your car looked familiar :)
https://www.sau.com.au/forums/topic/30059-spotted/page/525/#findComment-4320844
Nah I was drying my car in the carpark opposite Carlovers when you drove out of the Dominos carpark. You would have seen a red & silver R31 and a white Liberty with 2 blokes scratching their heads thinking your car looked familiar :(
HAHAHA!!! YESSS i did see you!!! :( awesome!!
I saw a skyline drive past and got excited then saw you guys and your cars and had a funny grin on my face so my mum was like DONT show off and im like wtf i wasnt going to lol I love my car :P
https://www.sau.com.au/forums/topic/30059-spotted/page/525/#findComment-4322009
Spotted a Series 1 R33 in Qbyn yesterday around 4.30, it was green (the factory colour, dont see that often) with a carbon fibre bonnet. I was in an old Patrol so i didn't wave. also a silver R33 with big FMIC in Karabar up near the traffic lights about the same time.
https://www.sau.com.au/forums/topic/30059-spotted/page/525/#findComment-4322090
white one was me.,... fairly sure i wasnt boosting round since its only stock...
i was waiting for pink melly.... looked like an exciting tennis game :blush:
https://www.sau.com.au/forums/topic/30059-spotted/page/525/#findComment-4322919
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
