hr32gts: He is usually seen driving down from the skate park, down past the waterfront and then back again. I've probably seen you a few times in Gunners but funny thing that recently i havent seen many skylines around.
And TITAN!! You didnt come in on Tuesday...everything ok or just too tired?
Also did this ford laser have any vinyl detail on its bonnet. I have seen one of a green varierty with detail on the bonnet driven by a bunch of girls before and when i was in my civic when my line was getting fixed they pointed at me and laughed...probably cause they could see their reflection in paintwork..dunno.
Oh! Who was having a go yesterday around 4:00pm on the road coming off flemmington before aussie junk?
https://www.sau.com.au/forums/topic/30059-spotted/page/550/#findComment-4523619
I'm going to Newcastle
but I will be popping down to sydney for the pizza cruise on sunday arvo/night.... if he was attending or even just came to the meeting spot in Chatswood I'd be happy to take your 'bits' :sick:
pee.ess. I got your PM... will check when I get home :)
https://www.sau.com.au/forums/topic/30059-spotted/page/550/#findComment-4524500
you were hiding out the back would have been 6:00-6:15
https://www.sau.com.au/forums/topic/30059-spotted/page/550/#findComment-4526313
Titan: Hiding...never...sitting on box pile...yepyep ^^
I had a trainee so...made him do the work.
Shell: I wont work till Saturday night, so cannot say if there will be a sandwich. But check the used by first...its usually up to me to check that half the time ><
Spotted a gunmetal R34 GTR V-spec in Fyshwick on Townsville st when i was leaving it. Parked on side so probably worked around there. I was in the green thing.
Also say a R33 pull into gungahlin Woolworths servo on wednesday. I was the one who forgot to turn off their alarm before trying to start the car ><
https://www.sau.com.au/forums/topic/30059-spotted/page/550/#findComment-4526990
Spotted my car back in my driveway at long last! Can't thank Ed and the other guys at Autotech enough for all the time and effort that went into fixing the issues with my car, it's a shameless plug I know but it's great to have it back again.
Spotted a midnight purple GTR yesterday near DFO with big front mount IC, the owner watched me go past but didn't wave or anything.
https://www.sau.com.au/forums/topic/30059-spotted/page/550/#findComment-4529955
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
