Can't say I've noticed that! With my new tyres and some fixed suspension my baby is holding to the ground like glue!
Spotted a gunmetal (or was it silver??? too early in the morning!) 33 turning from Ginninderra drive onto the GDE this morning on my way to work. As per usual when I make spottings, I was in the Audi :down:
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883246
Hmm well the tyres are nearly two years old with about 20,000km on them, i think.. Although, Kat, are you running the RS-R's, mine are only the SS's..
Nope I be running Bridgestone RE55's.
Funny though, you get used to how your car is feeling, I knew it needed work but I didn't quite realise how bad it was until I remembered how good it could feel when I got it back. I think that makes sense... Oh well it's Friday and my brain has officially shut down!
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883943
Also W1ngnut and someone in a gunmetal 32 with an SAU sticker that I haven't seen/met before both on Monary hwy this morning.
That was me :P - BTW it's Silver not Gun Metal (its a bit dirty at the moment though).
Haha spotted Trozzle and Bullet32 on Monaro this morning. Does anyone else think the roads might have a lot of dust/dirt on them? I felt like i had very low grip on the way to work and I don't think the 595's are due to be replaced already..
It was very slippery on the hwy this morning, its the left over crap from dirty rain on the surface of the road after the water dries up.
P.S. I love the wheels on your car! :devil:
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883999
RHGY? Did you cap it before FW? wait, wtf....
Dead guy? wowowwwz explain
by Rh. I meant rush hour. wasnt sure if i wasnt meant to mention it. haha
and yer after everyone from rush hour went to the strip club, my friend and i (we both arnt 18) were driving back home and we saw heaps of cops taking pics of some dead guy.
has it been on the news yet?
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4884648
Your running RE55's for the street? :D
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4886294
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
