Spotted a REAL midnight purple 33 GTR in Civic, a bunch of random 33s and 32s no doubt doing formal runs, white 35 GTR out the front of tongue and groove, and a silver 33 this morning on the monary heading up the highway from Johnson drive
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4970140
Yesterday I saw: Black Chaser with half a cage, Maroon 32 with the front bar falling off (worse than mine, it was missing a light too), white 33 (twice), a gun grey 32 and a light blue Audi R8 I was stuck in Traffic with it...
Previous day I saw a white 32 at the hyatt as well as the 33 and 34 I was driving with :)
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4970179
Ouch, 4 demerits?
Yeah man, 4 points cause i was in the 30+ bracket.
Just for my convenience there was a 10% increase in fine amounts about 3 days ago.
Its my first ticket in about 3 years, so I have had a good run. Lucky i wasnt in the skyline, I reckon he would have sent me over the pits just for the sake of it.
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978085
Nasty - good reminder for us all to watch our speed and stick to the limit. not worth having your insurance affected, let alone contributing to the ACT coffers...
I feel for you, been there myself...
Or letting them have any of your money encouraging them to go out and fine more people!
Spotted a grey R32 GTR near the Pommy Car Show on the weekend, I waved and didn't get one back. It's a weird feel that LOL.
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978180
haha it's not so bad if you're not sure whether they saw or not... but when they just STARE back you feel like a complete tool :)
Spotted an R33 GTR in either purple or black turn off Drakeford last night into Kambah about midnight..
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978190
oh also I've spotted plenty of skylines around the past few days, particularly last night. Pretty sure a couple have given a wave, but I was too late to react each time, and more than likely changing gears....to those of you who this is - sorry I don't wave occasionally, if I see you in time, I'll always give a wave :)
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978367
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
