Spotted a REAL midnight purple 33 GTR in Civic, a bunch of random 33s and 32s no doubt doing formal runs, white 35 GTR out the front of tongue and groove, and a silver 33 this morning on the monary heading up the highway from Johnson drive
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4970140
Yesterday I saw: Black Chaser with half a cage, Maroon 32 with the front bar falling off (worse than mine, it was missing a light too), white 33 (twice), a gun grey 32 and a light blue Audi R8 I was stuck in Traffic with it...
Previous day I saw a white 32 at the hyatt as well as the 33 and 34 I was driving with :)
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4970179
Ouch, 4 demerits?
Yeah man, 4 points cause i was in the 30+ bracket.
Just for my convenience there was a 10% increase in fine amounts about 3 days ago.
Its my first ticket in about 3 years, so I have had a good run. Lucky i wasnt in the skyline, I reckon he would have sent me over the pits just for the sake of it.
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978085
Nasty - good reminder for us all to watch our speed and stick to the limit. not worth having your insurance affected, let alone contributing to the ACT coffers...
I feel for you, been there myself...
Or letting them have any of your money encouraging them to go out and fine more people!
Spotted a grey R32 GTR near the Pommy Car Show on the weekend, I waved and didn't get one back. It's a weird feel that LOL.
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978180
haha it's not so bad if you're not sure whether they saw or not... but when they just STARE back you feel like a complete tool :)
Spotted an R33 GTR in either purple or black turn off Drakeford last night into Kambah about midnight..
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978190
oh also I've spotted plenty of skylines around the past few days, particularly last night. Pretty sure a couple have given a wave, but I was too late to react each time, and more than likely changing gears....to those of you who this is - sorry I don't wave occasionally, if I see you in time, I'll always give a wave :)
https://www.sau.com.au/forums/topic/30059-spotted/page/597/#findComment-4978367
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
