he he i set a cars alarm off in dickson last friday..
and then some stupid bloody pedestrians walked out on the zebra crossing in front of me.. what the hell!! i was driving there!! did they want to get hit??
in my pervious car, a BMW, i used to set car alarms off with my stereo :D
https://www.sau.com.au/forums/topic/30059-spotted/page/604/#findComment-5048652
Nice sig pic Shell!! :(
Thought it was about time I put my car in since i don't have any banners for events taking the spot atm!! :P
i spotted a white 32 gtr in homeworld today at around 2ish in my 33 then when i was in the vl i spotted a yellow 34 at the light where kambah high used to be both were very tidy looking cars
That would have been me... were you in the Walkie VL??
https://www.sau.com.au/forums/topic/30059-spotted/page/604/#findComment-5049309
I could be wrong in my assumptions, but the owners of 34 and 35 GTRs in the area give the impression to me that they're too good for SAU...moreso, they give no impression at all, because while I am 99% certain they know of the website and forums, they never post or reply to spotted's...
ah well, such is life.
Hey! I take offence! I usually reply to posts of when I am spotted - though I am not on here that frequently as I'm too embarassed to look at the forums whilst I'm having troubles with my car. I think someone posted about it later on in this thread about my R34 blowing flames around DFO... gotta get her fixed!
https://www.sau.com.au/forums/topic/30059-spotted/page/604/#findComment-5060153
Spotted r32 athllon drive near mawson gave a wave got one back, and purple 33gtr, white 32 with black bonet, white 33 and silver 34 near where I was parked in Woden area earlier
spotted purple r33 with gold rims near torrens/pearce, and could have been my silver r34 at woden parked underground on sunday
https://www.sau.com.au/forums/topic/30059-spotted/page/604/#findComment-5060693
Spotted a white R33 at BP Phillip.. large islander(?) guy with fluro work wear top on
Then a red R33 in Fyshwick, I did see you wave at the last minute, and waved back but you probably didnt see!
Then bayside blue R34 GTR on Pirie Street
Then a white R33 in the Woden underground carpark leaving just ahead of me
https://www.sau.com.au/forums/topic/30059-spotted/page/604/#findComment-5060742
Also spotted a red R33 in Fyshwick, I waved, didn't see if she waved back. Saw a white R33 just up from woolies Conder, heading to Tuggers at about 6:15am.
Lastly a (I think white - can't remember) R34 heading into Hume from Queanbeyan at about 8am.
https://www.sau.com.au/forums/topic/30059-spotted/page/604/#findComment-5061165
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
