Spotted Kat today from Gungahlin lights up, then up the barton highway. I was on the green ninja.
Love the sound of your motor. Gave you a wave but you wouldnt have seen me through the mirror visor.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5104287
Spotted a white 32 4 door with a black boot and fuel cap cover driving from holy family all the way to Gordon direction driving like a granny around corners but would give it a hit (if they manage to be in the correct gear exiting the corner) on the short straight bits...then I believe a black 34 was up my arse while I followed the 32 who then followed them further when I turned off.
And wow my grammer is terrible haha
ps I was in the black ute
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5106075
Blue 34 GTR on Yamba drive near the hospital, was stuck a couple of cars back and couldn't get in closer for the wave :blush: also I believe ZANE this morning as he went up the Hindmarsh exit ramp from Monaro heading south...I was on other wise of the highway
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5106330
Saw a charcoal grey R32 GTS-t at the RTA carpark in Queanbeyan today (that carpark is designed to break cars i swear) female driver, looked pretty stock save for the exhaust. If the owner is on here i was parked next to you in the white 260Z.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5107785
Blue 34 GTR on Yamba drive near the hospital, was stuck a couple of cars back and couldn't get in closer for the wave :P also I believe ZANE this morning as he went up the Hindmarsh exit ramp from Monaro heading south...I was on other wise of the highway
yay i got spotted!!! but i didn't even see you lol
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5108256
That was my car but a friend is borrowing it due to hers overheating.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5110635
Nah mines silver and no GTR kit. I only go that way if Captains Flat Road has been freshly grated, otherwise I go the long way around or I take my falcon.
I have seen yours, but not for a long time. do you go out that way often?
yeah, once you are past the dirt section out the back of captains flat, the road is awesome :down: long straight tarmac right through to braidwood! it cuts my travel time to the coast down if I go that way - just need the dirt section sealed...
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5110920
I used to, not so much anymore. I normally take my green EL falcon but sometimes I just can't be bothered putting up with slow. The dirt road is REALLY fun if it's grated but the moment it rains it's just. Not good. I used to drive that road every night at about 1am. I used to get very sideways, it helps having your headlights where your going, rather than off the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5111764
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
