^ ^ Apparently that car is running close to 1000hp, coz I talked to the owner not long ago, I think he's around the jerra/qbn area?
Spotted a very clean looking gunmetal r34 gtr in fyshwick around lunchtime, they probably thought I was odd as I waved my kebab at them :/
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5767851
saw 2x R33's at supercheap tuggers at lunch time.
one was black with gold speedy envy's and a big gold rushhour sticker
the other was a yellow acid metallic colour sitting low with 19-20" black and machined rims (maybe zenetti)
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5778910
eww
lol
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5779305
eww
lol
+27ty
There are some fkn horrid cars down this way...saw a dark green JZZ31 (non turbo) soarer this morning, Not only did if have the ugliest kit I have even seen on a Soarer, it wasnt painted, had some stupid aluminim T wing and 2 HUGE cannons poking out underneath and standard 15" wheels with what looked like 185s all around.
There is also a mint green R33 with not a straight panel on it, front bumper hanging loose on one side and has a Veilside rear wing, but with out the airfoil part of the wing...so it just has the 2 sides sticking up off the boot lid.
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5781135
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
