^ ^ Apparently that car is running close to 1000hp, coz I talked to the owner not long ago, I think he's around the jerra/qbn area?
Spotted a very clean looking gunmetal r34 gtr in fyshwick around lunchtime, they probably thought I was odd as I waved my kebab at them :/
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5767851
saw 2x R33's at supercheap tuggers at lunch time.
one was black with gold speedy envy's and a big gold rushhour sticker
the other was a yellow acid metallic colour sitting low with 19-20" black and machined rims (maybe zenetti)
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5778910
eww
lol
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5779305
eww
lol
+27ty
There are some fkn horrid cars down this way...saw a dark green JZZ31 (non turbo) soarer this morning, Not only did if have the ugliest kit I have even seen on a Soarer, it wasnt painted, had some stupid aluminim T wing and 2 HUGE cannons poking out underneath and standard 15" wheels with what looked like 185s all around.
There is also a mint green R33 with not a straight panel on it, front bumper hanging loose on one side and has a Veilside rear wing, but with out the airfoil part of the wing...so it just has the 2 sides sticking up off the boot lid.
https://www.sau.com.au/forums/topic/30059-spotted/page/660/#findComment-5781135
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
