CORRECT YOU ARE, RICHARD. lol.
Also just parking the van now (on the street again, sigh) and I noticed mirror glass all over the road and some pieces of plastic. f**king sigh, looks like the dream boats are smashing more mirrors on the same f**king street. My god!
https://www.sau.com.au/forums/topic/30059-spotted/page/737/#findComment-6339028
White R34 GTT driving past the convention centre towards civic yesterday about 5:30pm looked nice :)
silver R33 GTS-T (with a GTR badge) parked up from Qbn rego office
white R33 with GTR wing on state circle near DFAT buildings (needs a wash :) ) about 8:45am
Silver R33 GTS-T driving past customs house towards conventino centre this morning about 9:00am
Edited by DAN00H
https://www.sau.com.au/forums/topic/30059-spotted/page/737/#findComment-6339241
Always seeing 33's outside work as above.
Regularly see a white 34gtr in queanbo on footy training nights?
https://www.sau.com.au/forums/topic/30059-spotted/page/737/#findComment-6341928
