Spotted silver 33 4 door carrington street queanbo. Sorry man I know you said you were on here, forgot the name already lol. Just wanted to say nice sounding ride!
DJBarnstar ???
Spotted a Maroon S1 R33 with Silverish Rims on the GDE @ 6:50am ummmm... Yesterday it was.
https://www.sau.com.au/forums/topic/30059-spotted/page/805/#findComment-6739302
Silver 34, black rims. On Monaro highway nearst rose cotage turnoff. Helping a brake down with horse float.driver caused top stuff and a good rep.
Nah Richard its a long story. that dude caused a crash and fled the scene so I followed him. If you saw the Obrien vehicle across the servo that flipped, the horse float driver caused it.I thought he was going to stop but he didn't.So I just bolted after him to get his plates. He looked mental so I stayed in the car till he left then I got out to take pics of the horse thingy.
Funny thing is that I was thinking if he doesn't stop before the cameras I have to slow down to 80 then speed up to get a pic of his plates.If I didn't, was definitely going to loose my license being a P plater and vigilante actions are against the law.
https://www.sau.com.au/forums/topic/30059-spotted/page/805/#findComment-6745733
Ah ok - I did see the Obriens van all smashed up and another beside it, obviously checking to make sure all was good.
Didn't click to me that the other guy had caused it.
Any how - well done for following the Horse float guy to get details.
https://www.sau.com.au/forums/topic/30059-spotted/page/805/#findComment-6745784
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
