Spotted me being a tool in woden darting between the 2 speed humps only to have a dark coloured 32 driving towards me about 8ish. Soz
Spotted a white 34 (GTT? Enkei rims?) at chicken spot at erindale at 9pm. Was at the servo. Car sounds good!
Also spat a LH front inner CV joint on the stagea yesterday :(
https://www.sau.com.au/forums/topic/30059-spotted/page/848/#findComment-6899058
White R33 coming out of Charnie Shops 7:30pm. He gave it a little fang past the Servo... (I was at the Servo)
(apparently Caltex is out of 98 til maybe Tuesday? had to get Shell instead. First Time in over 2.5 years I haven't used Caltex from Kippax.) :(
https://www.sau.com.au/forums/topic/30059-spotted/page/848/#findComment-6902047
